You'll need to remove the compression fitting off of the air hose on the Spyder, and unscrew that fitting and install it in the 097c. The compression fitting is on the right of this pic. The manual says to use Locktite 597 on the threads, but I could not find that in my area. I used a product called Rectorseal 5, that seems to work well.
Once that is done, you'll need to cut the connector off of the old compressor, and solder it to the new one.
Note that the 097c compressor is round, whereas the old one has flat sides. This is why you need to get longer bolts. I used M6 1.00x40, and they worked well.
Once you mount it, and reconnect the connector, this is it:
And this is where I ran into a problem. The 097c is a tad longer than the old one. One side is right up against the battery compartment, and the other is against the brake line. The brake line worried me, but no matter how I adjusted it, there was no way to avoid it. What I ended up doing is using some thick pinball flipper rubber (yeah, another expensive hobby) to put between the brake line, and the compressor. I then zip tied all of this up so it can't move. There is no rough edge where it is laying on, but It still worries me. I will keep and eye on it though.
Also, you'll need to rotate the compressor in the mount. If the output valve part is pointing downward, the splash guard will not fit!
The only other issues I had were sliding the rear cargo compartment back on. It seems on the sides, it has to slide under the splash guard, which I did not know. One cracked splash guard later, I figured it out. Again, this will take two people!! Also, watch the schrader valve!! You'll need to feed it through the hole and twist it as you slide the rear on. One other thing is that I could not test the compressor until I put the seat back one. I assume the seat sensor is the culprit, but just double check you have everything hooked back right. You do not want to have to take everything apart again, trust me!
That's about all there is to it. I notice it is much quieter than my old one, and hopefully, it will stop the fuse from blowing when the Mrs. is on the back. So far so good!
