Put in a Cat Delete
scubadown
Yesterday I put in a Cat Delete on my 2013 STL. Mostly to reduce the heat in the confined engine compartment. Went pretty smoothly. Glad I read jwulf74's post on tips. At first I though I had bit off more than I can chew but, got it done. Also changed the oil and filters while I was in there. The bike has a more throaty sound but not really much difference. Got the Cat Delete from RLS Exhaust with a Ceramic coating. Used code Exhaust50 at check out and saved $50.
Have you ridden it enough to tell if there's a difference with the heat? Peggy's doesn't seem to be too bad, but any little thing can certainly
be a help with heat management.
Well the weather has cooled off to the point that I really can't tell any temperature difference. Next summer will be the real test. It does seem to have more low end torque and a nice sound.
