I have a new 2019 Cherokee 22RR that I'm using to transport my 2012 RT with and camp with. It has a rear ramp door but the angle is quite steep! A have reduced the angle as much as possible when loading or unloading! The Spyder has to be loaded by backing up the ramp! The toy hauler is wide enough to fit rear section first and then the front main body. --I . I'm having a problem with the throttle pulsing ( that is I'm holding in one position but the carberator or fuel injection pulses) It doesn't do it when I'm on flat ground and going in reverse! Does anybody out there have an idea what is causing this? Any thoughts ideas or suggestions? Please?
