pros and cons
cuznjohn
ok everyone what are the pro's and con's of the kool metal air intake system on a rt. do you need to pipe air to the area of the filter so it doesn't use all the hot air from under the body. what do you think
I don't have one yet, but in my research we gain a lot of room inside which can only help airflow. I don't think most people have added any sort of additional air pipe or anything, but at least a couple have. I think Teddy and Dave had the best setup. They completely removed the air box and resonator and added a bilge blower onto one of the stock air pipe pieces. Sounds like it really cools the inside down when switched one. I plan on doing that to mine that I might add an automatic thermal switch so I don't have to remember to turn it on and off or fiddle with it while riding.
Removing the airbox will probably free up some space underhood; that'll give the air more room to circulate freely...
BIG Pro!! :2thumbs:
Big pro - it makes it possible to access the front plug (and plug wire) without being a contortionist.
with two brothers exhaust dont notice any more noise unless full throttle acceleration over 6500 RPM, at that point i dont mind hearing the intake honk... you decide if thats pro or con.
Con - if you dont install a blower, intake temps could be elevated over stock setup if you let the spyder sit and idle for prolonged periods in hot weather. (or get stuck in traffic) Plan to install a blower on ours yet this winter.
Wasn't a member on here making a similar kit? But at a heap less money, I remember reading that on here somewhere seems like it was in the final stages.... :dontknow:
