Anybody else have alot of trouble with the clamp on the hose going onto the water pump?? The screw in mine seems to be working itself loose every 3-6 months, causing antifreeze to go all over. Is this a sign of the clamp going bad or just something I will always have to keep an eye on and make sure it is tight?
I have been tracking a leak for the last couple of days and after catching where it was coming from, the screw on the clamp turned 3 turns before real resistance showed up. Same situation back at the beginning of the summer, I should have know where to start looking first but didnt think about it. So just need to know if this is more common than I thought, or if a new clamp is needed. Thanks Guys & Gals..Merry Christmas to all.
