Princess and the Pea
NovaSpyder
Last Friday I was leaving for work and turned and backed up my driveway, then proceed up the street.  As I drove away I felt a bad vibration from the <img src="images/smilies/spyder2.gif" border="0" alt="" title="Spyder2" smilieid="51" class="inlineimg">.  Oh oh, so I pulled over to have a quick visual, didn't see anything falling off so I continued to work, about 3 miles.<br><br>Once there I did another visual, looked for loose brake pads, looked at the belt. Etc.  Still nothing.  I was hoping it would "go away" by the time I left for home. :pray: No such luck.  So I drove home trying to feel out the vibration.  The frequency led me to believe belt or sprocket.  So when I got home went over the belt very carefully then found it!  A very small stone in the rear sprocket.  I didn't think something so small could cause such a thump.  So reminded me of the old folk tale "Princess and the Pea". <br><br>I had been wondering, how would I know if I picked up a stone in the belt that could cause damage, I think I know now!  My ST1100 is shaft driven and previous bikes chain, and now that I think about it, had a frozen chain link many moons ago that caused a similar thump.  Overall no damage, just a :yikes:.
You are a lucky ryder. Thanks for describing it so we will have a better idea what to look for.nojoke:2thumbs:
Just sayin'............
:congrats: on having a finely-tuned butt, that detected the "pea"... :thumbup: No harm; no foul...
I always slow down to not much over a walking pace if I'm trapped on an unpaved section that I need to cross... :shocked:
Good point Bob on travelling on unpaved. I should point out that I was on paved surface at the time. The small stone was black so appeared to be a piece of asphalt. So you don't have to be on an unpaved surface to pick up a stone, though it is probably more uncommon to pick one up on paved surface.
My driveway is 2000+ feet of gravel. Have not picked any thing up yet. My max speed is 15mph, so I can't get out of 1st gear either.
It's amazing, isn't it? Even a tiny bit of tar stuck on the sprocket can cause a pretty substantial vibration. I scraped every single grove of my sprocket, geting out a few tiny pieces of compressed debris. The ride was much smoother thereafter...just like new. The stone I had in the sprocket did worse, of course...and like you it took me a couple of tries to find. Look your belt over carefully for stone bruises, tears, or holes. A stone can easily cause belt damage, which could result in shortened belt life and a delayed failure. Keeping a spare around isn't a bad move after an incident like this.
