gftempl
My 2010 Spyder RT/S suffered a major problem a few months ago. I was getting the DPS faults and other assorted faults kept popping up randomly. I finally took it into MMS in Conyers (only been there once before for oil change) and they replaced the DPS and the gear box position sensor. I figured the cost would break the bank (and it would have) but I had the extended warrenty and they were able to complete the work for only the deductible. When I got the bike back the high beams would not shut off. They did a quick check and determined the switch on the handlebar was bad (hibeam shutter controllable from computer but no signal from switch). I took the bike home while they ordered a new unit (replacable only as the entire LH package with all switches). A few days later they called to say the unit was in but had a recall on it so they reordered again. When that arrived I brought the bike back and they replaced the switches but the fault remained. They then performed a complete computer diag to try and locate the problem but found nothing. They called BRP who said they needed to inspect the harness looking for a bad connection. They tore the bike apart and found a corroded connection in the cluster that was the cause of the problem. All this took a month and several trips to Conyers for me (I live in Athens) mainly because I rode the bike there and needed to ride it home again. I finally trailered the bike to them so they could perform all maintenance needed (only one Spyder tech, Kevin, available and mine was not the only bike being serviced). All this work and effort on their part and Missy (service supervisor) had it performed under the original warrenty work.
My opinion of Conyers MMS service dept? They were great! They kept me informed of their efforts every step of the way and when they hit a stumbling block (after diags when they had to call BRP) they didn't BS me. They said "we're not sure, this is what we need to do, don't worry-we'll fix it!" and they did! If you take your bike there remember they only have on qualified tech at this time so you might have to wait, but they do good work and make you feel like they want your business. Kudos to Conyers MMS service department!
