Power commander or juice box
jroberts650
Has anyone installed a power commander or juice box on a stock spyder? Are there any benefits to doing so? If so, what were your results and opinion on either box.
Mine is completely stock. Changing plug wires tomorrow since mileage is 22,500 and just thought maybe the driveability would be better along with a little snappier throttle response.
I use the power commander on a 2014 RT. I did notice it runs a bit cooler and a bit smoother engine. Keep in mind it is not a tuner
So I guess it basically fine tunes tunes the power curve and throttle response? Is it worth the money to invest on one? If I ever do add anything it will probably be a Hindle exhaust.
It may give you a bit more throttle response and smooth out the VE tables. If you want a smoother cooler running machine then yes invest in one. But that is up to you. :thumbup:
