Welcome to the Forum, IanB. :thumbup: There's actually a few of us Aussies here - I'm based in SA, just a bit outside of Adelaide on the way to Melbourne, but with twisty Hills roads on my doorstep & wide open roads just a few minutes away, where are you? After all, Australia
IS a pretty big place, & we already have Spyder/Ryker Ryders just about everywhere!
....Apparently sport mode turns off traction control. Is the TCS intrusive enough that I should care about this?..
That 'Sport Mode' thing doesn't actually 'turn Traction Control'
OFF it really just turns it down a bit until you get going fast enough &/or add enough steering input that 'the Nanny' (as the Stability, Safety, & Traction Control systems collectively are affectionately known
) decides you're obviously having too much fun & steps in to calm things down a bit!! I reckon it is definitely an advantage having 'Sport Mode' on an F3, but it isn't impossible or really all that hard to learn the limits the Nanny gets antsy with, and learn to ryde within them - and if you can do that to any real degree, while you might not win every traffic light drag race, you'll certainly be able to win quite a few and there won't be much in the way of anything on 4
OR 2 wheels that'll keep up with you in the tight & twisty stuff with short straights :yes: And once you've learned how,
NOTHING that I've ever seen/driven will out-brake a Spyder anywhere!! :shocked: It's only when you get out on the longer straights & open roads where the sheer weight of the dirty great wall of air any Spyder/Ryker hasta push outta the way to go really fast comes into play & the boy racers will be able to really show you a clean pair of heels! But here in Oz, those sorta speeds are 'confiscate your bike AND licence' speeds anyway!!
Still, all Spyders & Rykers run engines that are significantly de-tuned from the factory - the lighter, peppier (& older & 5 speed) V-twins hit the streets with 100-105HP while the 1330's come out with 115HP or there-abouts, yet similar Rotax engines running in other platforms reliably produce 150+HP!! And it just so happens that we have here in Aust one of the best most experienced ECU Tuner of Rotax & CanAm machinery around!! Jase from
ECU Xtreme on the Gold Coast can release all that untapped power and more for you, and make your Spyder the machine it should've been from the start - or better!!
hyea:
Over to you, and once again, Welcome! :cheers:
