Placeholder. Am I allowed to do that I'm going to post here later I'm at work
Only if you post a brand new reply instead of significantly adding to or editing the above!
We try to discourage posts like that quoted, and certainly discourage people from editing out the bulk of the content of any post they might've put up earlier, because after any post has been up for anything much more than a few minutes, gutting that post or even significantly changing it is
almost as bad as deleting them - any of that stuff hurts the Forum's standing with all the search engines, meaning if it happens too much we get dropped down or even entirely off their displayed results, and
that means fewer viewers, which makes the place less viable for our owner/sponsors &/or less useful/helpful to continue to operate! :shocked:
And
THAT is why the '
Delete your own posts or threads' facility was removed a while back & is no longer available to members! :sour: Similarly, too much 'misuse' of the '
edit your own posts' facility as described above could well lead to the same thing happening to that facility!! :lecturef_smilie: So if you truly have something that is erroneous or embarrasing etc which you posted more than a few minutes ago & now want removed, we'd
much rather you contact a Mod (look for the
Green usernames!) and ask them to 'delete it' via PM, we can 'hide' them for you if necessary, rather than leaving a link to a significantly different, gutted & useless, or empty post!
hyea:
So really, if you want to '
place-hold', you should simply '
Subscribe' to the thread (see the drop down list under
thread tools, which is up in the middle/top of the first post on any page of a thread
) rather than putting in a post that you intend to edit later - that way you'll always be able to get back to the thread and more!! Of course, if you
have posted a valid response, then you can always search on the
Find Forum Posts link in your Profile, but by subscribing & ensuring your email address is valid & working, you can also choose to set your Profile to Notify you of any new posts in any subscribed threads or not, or you can get notified via PM, or not - and you can also change your mind about any subscription you might have later on, cos you can always remove the thread from your '
Subscribed' list at any time! :thumbup:
So you're better off
Subscribing to a thread than just posting 'place-holding' posts &/or posts you intend on editing later; please don't significantly edit, empty, or gut any posts you've already made, just ask a Moderator instead; and set your Profile up so you can use your
Subscribed list to your advantage! Make sense?! :cheers:
