Sarge707
https://www.revzilla.com/motorcycle...MI1oGkuMet4AIVg4TICh37zAmMEAQYBSABEgLxK_D_BwE
The stock windshield is OK BUT since you have 4 bolts and adjustability I am only going to replace the shield and NOT the hardware.
It can be done. The stock is about 12 inches at the bottom and ONLY 8 inches on top SO you get a lot of passing side wind.
This one is Not bulbous looking and is 16" at the bottom and 13" at the top which is a Big improvement that with a template you can bolt to the stock mount about midway up so you equalize the pressure on the mount and you can still adjust via the sliding bolt on the stock hardware. This is 18.5" tall so a small portion of the bottom may need a little trimming.
Can You find a Better simple bolt on economical (CHEAP) windshield from your past bikes. I,m not going to pay 2-3 hundred?
