The front end of our Spyders and Rykers are so lightly loaded that usually even the OE Spec Kenda tires can easily reach 10,000 miles without significant tread wear issues, and a good auto tire will probably triple that if there's no other factors causing excessive wear - so yeah, with just over 5K miles on your Ryker's front tires, I'd guess that there's something wrong with the wheel alignment, camber, or the tires themselves that's causing that?!? :banghead:
What position do you have your front shocks adjusted to?? If you wind them up too high for the load the Ryker with you & all your usual load (pillion, luggage, etc) on them and you'll probably raise the front of the Ryker beyond its ideal ride height and so cause the tires to have excessive positive camber & so wear the outside of each tire.... but if it
IS that, the wear pattern is generally a 'smooth' & evenly level wear right across the tread face, albeit just too much on the outside of both tires; or the inside of both if you've adjusted your shocks too low so that you've got excessive negative camber, but you'll usually notice the nose scraping on the ground first if that's the case
Back too much positive camber, if you gently run your hand along the circumference of a section of tread and then across the tread face, you also generally won't be able to feel any 'saw-tooth' edges on the front, back, or sides of any of the tread blocks. If you
CAN feel that 'saw-tooth effect', which is just a raised or sharp edge on any side of the tread blocks, while the opposite side is worn down more & smoothly, it's more likely that your tread wear issue is being caused by incorrect toe in/out; and once again 'generally', I'd be suspecting
that as being the cause of your tread wear before I'd be too committed to labelling it definitely as too much positive camber. Simply because very few dealers/Can-Am techs have any real experience, idea, competence, &/or skills in properly aligning Spyder/Ryker front ends, but
most can set the static ride height via the front shock adjustment fairly readily & get it reasonably close to 'right'.
So, have you ever had your Ryker aligned by someone widely regarded as being competent at aligning Spyders/Rykers? If not, then maybe that'd be a good first move, immediately before fitting a set of 'proper' auto tires that meet or exceed the load & speed ratings on your Ryker's tire placard.
Unless you're in some European Countries, you usually don't have to slavishly comply to the same nominal sidewall tire size, so you should be able to find a tire that's within about 20mm of the stated width & also only 1 or 2 profile steps up or down, but it will usually pay to try and keep the front tires & the drive tire reasonably close to the same proportional rolling radius, or if you like, keep them within +/- 10 or so % of the standard proportion in 'revs per mile'. The Nanny/VSS etc is really quite able to handle relatively small variations, but anything much over +/- 20mm is likely to prompt some minor but more frequent interventions, so if you want to minimise even just the chance of that happening, try to keep any tire rolling radius change fairly close front to rear. :lecturef_smilie:
That said, I can't recall which end of the Ryker rolls fastest, but I don't believe the front & the drive tires have exactly the same rolling radius or revs per mile, so if you increase the front by fitting a more readily available tire size, you may also need to fit a tire with the same or a similar proportional increase to avoid upsetting the Nanny too much, even if she's only likely to get a little upset - you almost certainly won't cause any 'limp home' incidents or other drastic interventions unless you also hafta modify the guards &/or swing arm to fit the different sized tires!! :thumbup:
Hope that's not all too confusing! :dontknow: . Oh, and I wouldn't expect too much help from your dealer, not only because of the previously mentioned lack of knowledge/skills/competence & even awareness, but also because back when we got a batch of soft compound tires that for some, didn't even last as long as yours have already before they were running on the canvas, the 'BRP Approved' response was pretty much just 'tires are a non warranted wear item, so what do you expect :dontknow: ' and basically they just left us all in the lurch! ! :cus: And
THAT's when many of us went to 'the dark side' and fitted some 'proper tires', which have proven over many many 10's of thousands of miles now to last longer, work better in all respects, and are usually a fair bit cheaper & easier to source too!
hyea:
Ps: I guess that sort of wear could also be due worn, damaged/broken, or poorly adjusted steering &/or suspension components too, but given that it's a fairly new machine, I'd still think it's
most likely going to be wheel alignment or incorrectly adjusted shocks. :thumbup:
