Popping & misfiring normal?
Many new motorcycle have popping and snapping noises under deceleration. This is normal because of the extremely lean fuel maps that are required by the enviro crowd. Once you change the exhaust it increases the lean running of the bike, plus the louder exhaust highlights this condition just because the exhaust pipe is louder.
The Spyder has a two stage exhaust system. The catalytic converter is also a noise silencer/suppressor, the pipe at the end is the second stage of the sound deadening of the system. If there is a leak at the joint between where the 2 bros connects with the exhaust pipe, that will also cause additions noises. Annoying, but not dangerous to the health of the bike.
The fueling system of the bike will compensate for the change in the pipe within certain limitations, but a PC V or other fueling devices will override the factory computer settings and set the fueling to whatever you program into it.
