Plate Holder
daddydarko
I had a custom plate frame made. Hopefully my plate will quit falling off!
Relocator plate bracket
Anyone have the plate relocator bracket on the spyder? I saw one that goes under the seat with a light kit. I would like to see a pic of it on the spyder.
Daddy, be sure you put the little velcro tabs on the bottom of the plate. Keeps it from vibrating to pieces. I also put rubber washers under the plate at the screws. This keeps it off the bodywork, and also assists with keeping the plate destroying vibrations down. Michigan's plates are crap. Half my historic plates have cracked. I have had to back up some with aluminum plate.
-Scotty
Our plate quality is definitely sub par. The mounting position on the Spyder doesn't help though. It would be nice if we could secure the bottom screws. What velcro tabs are you talking about?
When our Spyder was delivered, there were two velcro buttons stuck to the fender on the lower edge where the plate hits. You stick the opposite part to the license, and it secures the bottom. The parts book shows them as #293740028, but calls them dual lock washers, so I am not positive that is the right part. They also specify four, so they may be used at the top, too. Seems like I used rubber washers there, but I could be wrong. I imagine any 3/4" velco stick on buttons from a home improvement store would do just fine. Your Spyder probably didn't have them due to being repainted before you received it.
-Scotty
-Scotty
I'm pretty sure that is the right part number as those aren't really velcro but 3M Dual Lock fasteners. And four would be right quantity as there are two that mount to the Spyder and two that mount to the license plate.
Thanks Brian!
