Pit Bull Lift
The difference is night and day.
A Pit Bull lift or J&S lift are much more robust than a Harbor Freight our Craftsman or just about any similar lift.
Yes sir, the HF lift is fairly cheesy. I have one because it was given to me as a gift. I use it carefully to lift the spyder up in the air and then I stabilize the spyder with two small jack stands under the front shocks and a single car tire ramp under the rear tire. Then I remove the lift and I have plenty of room to work. By the way, if you have any HF jack stands check them to make sure they lock up properly. HF had some that failed and collapsed.
