Pirrelli P Zero ?
Amazon.com
Overnight or day or two
Easy to return stuff also
I love R&R put another dime in the jukebox baby!
My stock size rear tire is 335 x 25 x 20. TireRack usually has pretty good prices and right now it is $511 per tire, plus shipping. I appreciate your concern that I am overpaying and would like to know where you can buy them for a lot less.
i think that might be the zp runflat tire. what car are you putting it on?
Agree, the Yoko is a great tire. I have used one and installed a number of them on customers bikes. They have all been very pleased with the tire. Most of them balance with 1/2 oz or less weight. Very well made tire.
What size are you using when going to the Yoko S drive? I wasn't able to find the standard size when searching on either tirerack.com or discounttiresdirect.com Thanks.
205/55 - 15
I know the number says its a smaller size but those are nominal size numbers. The Yokos run large. Comparing actual dimensions, the tire is exactly the same diameter as a stock tire and less than 3/16 difference in tread width. Its a great fit.
This is the tire I am looking at for my next one...
Any thoughts from anyone?
Yes. Most if not all performance tyres are asymmetric and are designed to be mounted in pairs. I would expect that mounting a single one on the rear of a Spyder may bring it's own problems. Maybe two on the front would be OK but I would think very carefully about putting one on the rear. Just my opinion.
I think you're wise in avoiding asymmetric tires, but directional tires are a good choice.
Might go to amazon
Check out photo
Check description of tire & specs
Check out price
All pretty amazing!
Also note this is not an (all season tire)
It is designed for max grip wet or dry summer
Micro grooves, special Silicone enhancements etc
I think thats kool
Yokahama s drive baby yep
