Pipe wrap plus Cat bypass plus Akropovic muffler
Spyderdale
Question, I now have the Akropovic muffler on my 2013 RT and if I wrap the pipes and install the CAT bypass but leave the airbox stock will I have to add a fuel controller ? Such as the PC5
When it comes to removing the stock exhaust, airbox and cat, most people are OK with any 2 of those modifications before they need a fuel controller. I did all 3 on my 2013 RT and to play it safe, I went with the PC5.
Try this..!!
make the changes you want and test as you go. I have modified all and don't have a fuel controller. Many suggest it even if you don't need it. Compitition pipes are usually the ones needing adjustments. I have a hindle pipe and JT air filter...:thumbup:
