you sir are an inspiration to my love of LEDS...you are also the bane of my other half's bank accounts existence..lol
I started a few weeks ago on the LEDS for my bike. Unfortunately she has been a clever girl and has been very difficult for me. I am not a good soldering person so i went with butt connectors. Now my back lights dont display red bc i think the connector didn't get a good contact. Now to tear the bike back apart and redo all the wiring and learn to solder better. Also had issues with LED strips sticking where i wanted them so i used hot glue...mostly worked....except that one strip to light up the radiator fan which promptly melted after a 30 minute ride.
Oh I've learned a lot since starting this project. I've taught myself how to solder the wires together, I did give up an have a company solder wire leads to my strips and have jst connectors and then bought those connectors to solder onto my "wire bus harness " which runs down both sides of the bike and the connectors allow each plastic panel to be removed and the jst connectors unplugged so they come away cleanly. I also striped the over spray off the back side of the panels where the leds were going, used 120 grit sand paper to slightly rough up the surface and 3m adhesive promoter. Those leds aren't coming off ever again![]()
Now if I could solve my controller issues I'd be good. Remote doesn't like to send signal to the controller or the controller doesn't like hearing it. Replaced batteries in remote didn't help, next step is shortening power leads from battery to controller and see if that helps.
I've had a few emails and FB PMs with questions. I'm traveling so I don't have all of the answers with me......
But from the questions, I decided to go ahead and post a pic that previously I said I didn't want to post. I'm not really happy at the organization as you see it in the pic. It was in process, and I'm leaving room for one more controller. AND, I made them where they each are removable for maintenance. The larger unit in the lower left is the WiFi hot spot device. With it, I can use the iPhone app to controll the lights within about a 300' radius. The hotspot is USB powered so I installed a 12vdc - 5vdc USB power converter (hardwired). It has a spare USB 2amp outlet so I've set it up for the future.
Here's all of the LED controllers....
All of the wires enter and exit from the upper left of the saddlebag. I drilled about a 3/4" hole there.It's exposure to wet is very low. This shot does give a good view of the while LED illuminating the bag.
LOVE it RevJVegas!! I'd love to see it in person if you find your way north on 59
Man I would need to see your Spyder in person and take tons of pics. I would love to be able to do half of what you have done to our Spyder. Some of your stuff is way over my head. Look great!
We have always wanted to go to SF but its a bit far. Would require quite a few days off to make it there and back. One day I hope.Thanks so much! Darth and Psycho (old Darth) will be at Spyderfest 2015!
Had to rush to put all the plastic back on so we could take it to LA for Thanksgiving.LOVE it RevJVegas!! I'd love to see it in person if you find your way north on 59![]()
I'll let you know once I get to a "done" point, then maybe we should see about getting a few of the other H-town ryders together for an evening Sonic run or something.
