Pedal Commander—Holy bat guano Batman!
Pikester
Just installed the Pedal Commander and man, does it wake this engine up! Sport + is flat out scary. Super simple install and the fact you can adjust it with the app is a great feature. Only issue I see is, I think my gas mileage might suffer for a while. If you’re on the fence, it’s worth it. Ride safe, Pikester
Makes the bike perform as it should have to begin with. You will find that it makes for a smoother ride, especially on twisty roads because the on/off throttle movements won't be as abrupt. My fuel mileage on my 15 RT hasn't suffered.
Totally agree and I think it also makes for a safer ride, as the throttle lag is almost nonexistent.
Pedal Box will do the same thing. Both are great for upgrading the Spyder.
Yeah, it was a toss up between the PC & the Pedal Box. How do you like your MadStad? I’ve had one on other bikes and once you get them adjusted correctly, they work great. Surprisingly enough, the stock shield with the Puig deflector is not too bad.
