I installed TRICLED LED Headlghts for the Spyder RT (which by the way was very straight forward) but during the process I decided to install the PDM60 that I had laying around. I installed the PDM60 under the left service panel (it was a flat area in that spot) using zip ties. The red positive cable length was perfect in this location I was able to connect directly to the batter positive post. I had to add roughly a foot to the black negative cable using the Post-Lock connector and connect it to the battery ground post.
I would like to connect the Ignition Trigger cable (grey wire) to the headlight (positive voltage when engine starts). These are the two connectors that were connected to the headlight.
For the five pin connect, Pin-1: Grey with Orange stripe wire, Pin-2: Brown wire, Pin-3: Grey wire, Pin-4: Black wire, and Pin-5: Brown with White stripe.
The two pin connector has Pin-1: Orange wire and Pin-2: Black wire.
Which wire should I connect the trigger cable too?
