Passenger seat button power limiter
Wildrice
There is this spring loaded big button assy under the rear seat. I've been told that is purpose is to reduce power output when a passenger is aboard that seat. Does anyone know what % of reduced power, or has anyone removed this device?? Acceleration is always difficult to judge when there is an extra load on the bike.
PS: Don't tell my wife I said she was an extra load--she varies between 118--120# & she is very sensitive about her weight increase from 115#. I told her not to wear her bra & that would reduce some weight.:yikes:
Signed,
Bob Denman
Bob--U didn't want me to get my as* kicked--did you:yes:
:shocked: :hun: A "Power Reduction" switch?!?
If it's the same one that the RTs have: it reconfigures the VSS, so that it can take into consideration the presence of a passenger.
But it doesn't reduce power!
Like Bob said ^ No power reduction AFAIK, but it does change the braking bias & Nanny intervention to cater for the additional weight carried above the CoG. ;)
Any 'loss of response' you might encounter is probably only due to the extra weight load, but maybe you shouldn't tell your wife that! :shocked:
Info I received from the dealer when I took delivery---kinda scary --huh. Thanks for the clarification:clap:
Darrell
What..!!
It's like the ones in many cars that sense when there is a passenger and turn on the airbag....if you disconnect it you will hear from the nanny....:lecturef_smilie:
If your wife only weighs 115-120 LBS you need to learn to shut your mouth and be grateful or we will be reading your Obit.
