Parking brake won’t engage - what will make it engage again?
Abeaurline
Hey all. So today, my parking brake decided not to engage. I’m 3 hours away from the nearest Spyder dealer who will work on my 2011 Spyder RT Limited. I’ve had a brake failure light that’s been on for months now too, but when I pulled the code, it’s a low pressure fault.
My question: how do I fix the parking brake to make it engage again?
Have you checked your brake fluid level to make sure it is at the full mark?
You might need to adjust/tighten the cable that operates the Park Brake up a bit, but given that you've had the Warning Light on for a while (as noted, possibly the Low Pressure switch?) and now this, could it all be a combination of the fact that your rear pads have worn down that far & your brake fluid level has dropped as a result?? :dontknow:
