Tasian
Okay, I did a search for this issue and came up empty handed...so I'm hoping someone out there can assist.
On my 2014 RT-SM6 the parking brake warning signal goes off every time I remove the key if, and only if, I push the parking brake button. The warning occurs if I set the brake and remove the key, if I set the brake & then take the brake off and remove the key, or if I set the brake & then take the brake off & then turn the brake back on and take out the key. Basically, if I touch the parking brake button and remove the key the warning goes off.:gaah:
I know I can just not set the parking brake since this is a SM6...and I do that to avoid all the stares for the 30 second interval the signal goes off...but I'd prefer to be able to use my parking brake without the :spyder2: beeping at me as I scurry away.
I've exhausted my knowledge and I'm hoping someone here knows how to do a quick fix for this....that way I don't have to go and spend time at the dealer when I could be out riding!
Thanks in advance....:thumbup:
