PARKING BRAKE QUESTION
JKMSPYDER
​I’m getting ready to replace my rear brake pads soon. I have watched the video from greatrides and it looks pretty easy. But something the video didn’t address is whether the parking brake should be off before I begin?
PARKING BRAKE
Absolutely !!! .... because if it's on the calipers are squeezing the pads against the rotor ..... you won't be able to get the caliper off ... when you stop the engine, it will beep for about 30 seconds +/- ....then start your brake job ..... Mike :thumbup:
...and don't forget.....
..... to unscrew (screw bach to open the space to insert the pads) the piston. Otherwise, the pads won't fit in or the pads/caliper assembly won't fit over the disk.....
