Parking brake "motor"
joebryanjr
Anyone else ever had a bad parking brake motor? It pulls in the brake but does not hold.
Mechanic says he has never seen this before. Am I a lucky exception?
Interesting..!!
not familiar with the system, mine is foot operated, but thought it had a ratchet lock..interested in finding out...:popcorn:
My technician has seen this once before. The parking brake would be applied but the unit would still roll if on a hill. The motor was not pulling "hard" enough to put enough force on the brake pads to hold the unit. Replaced the parking brake motor and was all good. Only saw it that one time though.
That is what my tech said, also.
Curious..!!
has the cable been adjusted properly..?? If the adjustment is loose then the motor pull is not enough. Might tighten it up a bit and see if the hold is better..:thumbup:
Thanks for the help. Kevin at Cowtown tried adjusting it but the motor does not hold. They ordered a new one.
