groundeffect
Registered User
Generally, after how many clicks do you stop pushing down on and engaging the parking brake on Spyder GS/RS?
Thanks
Thanks
I hardly, if ever, use it on my SM. Just leave it in first gear unless I happen to be on a very steep incline. When I do use it I'd say 3 clicks.
I just had a badly stretched cable replaced. It now locks up tight with one or 2 clicks.
Thanks
Spec is one or two clicks. I adjust mine if it gets to be more than four.
Wow, 3 clicks. On my brand new RS 2010 I use one click and it locks it up nice and good. I don't want to push it more then that, as it takes a good amount of force to get the first click and works fine at that setting.
Mine is brand new (RS 2010), so perhaps that indicates the difference in the number of clicks. I suspect your brakes are worn in more then mine.
Thanks for the reply.
Your parking brake sounds like it was set up by the dealer fine. One or two clicks is what you want. More clicks and it is time to adjust. As long as your parking brake isn't dragging when off. From this and your other question about resistance to turning the rear wheel it sound like your dealer got it right. :clap:
I should have been more specific, and said that this spec was provided by my technician, after he did the parking brake service bulletin. Don't know if the spec is in the service bulletin, or was provided by the BRP tech people, but that's what he was told to adjust it to. I don't think it is real critical, but if it is too loose, it will not hold, and tends to stick and not release.Spec is one or two clicks. I adjust mine if it gets to be more than four.
+1:agree:Spec is one or two clicks. I adjust mine if it gets to be more than four.
I suggest you learn to do it yourself (or teach your wife, LOL). This is one of the quickest and easiest maintenance procedures on a Spyder. Look in your Owner's Guide.I definitely need to get mine adjusted. My wife's Spyder works at 1 or 2 clicks, but mine takes at least 4 now. I have a very hard time releasing it while sitting on the Spyder, so I have started doing so before mounting and still have trouble at times. I suppose this will be a good test to give the next dealership I visit.
I probably wouldn't use it either, if it wasn't for that annoyingly loud beep when you shut off the SE5 and don't have the parking brake set.![]()
