Rebob
Went to work this morning as usual. When I parked I set the parking brake and the parking brake fault light came on. Tried to set and release it several times to no avail. So I set a block under the tire and went to work. When I got home I took off the side panels and looked. The cable ends were in place. When the cable released, the cable would not return all the way and had a small bend not a kink. I cleaned the dirt off of the brake cable and put a little bit of oil in the cable casing and it worked like a champ. However, the Parking Brake Fault still comes on. I even checked the brake fluid reservoir and no change. This is just great. Suppose to be heading to Colorado in 4 days and now I'm worried. Anything help is appreciated
