All
2011 RTL just finished a brake bleed and took off the parking brake to reach the bleeder. Did a test run and all was good until I set parking brake. Got Parking Brake Failure and no beeps. Checked forward pully and found cable loose. Reattached cable and brake now works but still have the Parking Brake Failure message and no beeps. Looks like the micro switch on front pully is bent and the lobe on the pully is chipped. Also noticed the inside brake shoe is worn Do I need BUDS or can I adjust the pullys and cables?
Thanks
Captc
Thanks
Captc
