Parking brake failed! Think spydee is DOWN and OUT this time!!
So sorry for your troubles. On my 2008 GS SM5 I eventually just removed the parking brake as it was always problematic. On my 2012 RT SM5 I find myself using it while warming the bike up.... but it's push-button operated and therefor more consistent on applying the proper pressure.
A fire would have been rare since an ignition source is required... and with the Spyder off... there should be no ignition source.
I would highly recommend that SE owners use the steering lock when parking on an incline since you cannot leave the Spyder in gear like SM5 users can. With the handlebars locked... the Spyder isn't going to get far or build up speed.
Good luck with your insurance claim!
This is good advice! I have a 2008 SE5 and ALWAYS lock the bars. Also, get familiar with the parking brake adjustment, check it often and don't leave it up to someone else. Again, very sorry for your trouble.
I know this doesn't help you now unless they wind up totaling out your unit but the new 2013 has a self adjusting parking brake that never needs adjustment. :doorag:
I was just telling a friend that I did want a new 2013 ST Limited, but this was NOT the way I wanted one. I already thought of that if they do decide to total mine out. That yellow color sure tends to grow on you. And now it comes in both models. :clap: I did not know that about the new brake, so thanks :thumbup: that's just another plus in my book. Let's wait n see.....:popcorn::popcorn::popcorn:
The electric brake on the RT sounds good but I'd like to see that mechanism before trusting it too much. I must be a real cynic.
It works very well. You can't move it by hand. And if you try to drive off with it set it'll stall the engine. Like Firefly, I always park in 1st. and if I feel I need added insurance, I set the brake as well.
Bumblebee67, hope everthing works out in your favor.
