That is a super idea:thumbup:... I am always dropping the screws when I take body panels off.
One other idea... I did it before all of the screws were replaced with Dzus fasteners.
I used stainless steel washers that are bonded to rubber on one side.... from McMaster-Carr... 1/4" ID.
These are good all around, from the plastic to the windshield.
http://www.mcmaster.com/#washers/=3z1sfg
Just an option for you.hyea:
Very nice washers only $3 a pop.
I used your link and selected stainless steel silicone rubber backing. I'll definitely try searching on their site some more.Hmmmmm.... don't know what you looked at but it was $13.00 for a pack of 100.... $0.13 each.
Yes - I ordered part #
[FONT=Arial,Helvetica,Sans-serif]94709A214[/FONT]
I'll let you know when I get them if I ordered the right part. Should arrive Monday.
I know the first member that posted placed the o-rings on the inside to hold the screws in place when the panel was removed. Do these rubber backed washers also go on the inside of the panel?
I suppose one could but I plan to use them on the outside.
They could go on both sides... as a washer and as a keeper.
The screws already have a plastic washer on them to keep the metal screw head from scratching the panels. It is very thin and they are expensive from OEM. Already tried o-rings on the outside,they distort when you tighten the screw. Has anyone found them else where? If so let us know!
ataDude,
I understand why you went to the dzus fasteners; but, what was the benefit of going to the bonded washers?
