pair sena shm10b
gmcgarrity
I am having a problem with the Sena SHM10B holding pair.
When I turn the 2 helmets off I lose it.
I have to do another pair every time I start.
what am I doing wrong?
ride safe
Geo
Hi
Dave here, Check the part number of what set you have I do not show an SHM10B in the SENA
line up... Could you mean the SMH10D-10- or SMH10D-11???
You will need that information, go to www.senabluetooth.com then click on the tech support
and tell them your trouble they will walk you through the pairing.
The tech support department there is tops they always help
Dave
ride safe
Geo
SENA headset pairing - similar issue
We've had our SM10 bluetooth transmitter with our SMH10 headsets about a year. Last year after initial start-up issues. We had them paired and they would stay paired the entire riding season.
This year, I did the update just before using them and guess what? My helmet does not stay paired.:banghead::yikes: I have their 800 number from before and may need to contact them. It has failed the last 6 times or so. My wife's helmet pairs just fine!
I really like the system, but the pairing can be a "pain" when it doesn't work like it should.
If you find a remedy, please post it....I'll do the same. :thumbup:
I won't be working on it until we can ride again which will be at least a week based on our :cus: weather!
BTW: This youtube video might be helpful if you're new to pairing the SENA system: http://www.youtube.com/watch?v=9NKE0V78USs
UPDATE: I reinstalled all the firmware on the bluetooth transmitter and headsets. They seem to be pairing up well now. I used the SENA website (thanks Motorcycledave) www.senabluetooth.com.
IF you need more help, I have SENA's Technical Service number ....it is: 866-300-1235 (I had to wait about 15 minutes for a tech to come on line, but when they did, they knew how to help me (I used this about a year ago when I first had my SENA system)....good luck).
OK loaded new software and it works fine.
This is the new Bluetooth system from BRP
SMH10 helmets pair with the BT SM10 to stream the radio to the headset
To listen to the radio press the large button and both headsets hear the music.
press it again and talk.
Not sure if the command can be set to VOC.
The headsets will now pair on setup.
Life is good
Thank you all for the help
Ride safe
Geo
Life is good
Ride safe
Geo
Great! Glad it worked. When I read the manual the first time it was very confusing on how to pair the units....that's why I called the SENA Tech. I'm glad you got it working! :thumbup:
