Paint Code
CJ/johnnyg
Can anyone tell me where I can get the paint code for the 2013 ST pearl white. We want to get the 622 trailer painted to match Johns St. The trailer is blue now that match the RT that he traded in when he got the ST
Here you go. 2013 is Vegas White.
Vegas white has to be applied in two stages since it is a pearl paint. If you go with factory application methods you will need to find a shop that can paint using water based paints as that is what is used in Canada. Failing that any good paint shop should be able to match the side panel off of your Spyder using a Spectrograph.
When you paint the trailer you will have to decide what to do with the stone chip protector at the front. The factory mylar is an expensive piece that you will have to replace unless you are just going to sand it off and not use protection. We chose to not use the factory piece and just had the body shop use bed liner to cover the area protected by the mylar.
Thanks everyone for the info. We are getting estimates now we will show you the pics when its done??? John and CJ
