If you put that code '
P0122' into the
Search field (top right corner of the page) then check the '
Search titles only' box below it before submitting the search, there's already a bit of reading here on the Forum for you to check out. And if that info is not enough reading for you, try unchecking the '
Search titles only' box and re-submitting the search, but be warned, you might get more than you bargained for! (Which is why you usually don't want to do that on your initial search...
) There might even be a thread on that code listed in the '
Similar threads' block below, check it out.
I'm not sure if any of the threads Search brings up will help a lot, I only gave them a bit of a glance to see if they were talking about the right code, but it does show why it's always a good idea to
Search FIRST, and then only start a new thread if you can't find an answer. By searching first and spending a bit of time reading, at the very least, besides not being the person asking the same old question yet again (we're
STILL trying to cull some of the bloody oil threads asking the same old same old questions!
) you'll get some idea of how prevalent the problem/that code is, and who knows, if the info in those threads gives you some insight into the problem, your question for a new thread might be a little different, or it might not be necessary at all!
Good Luck!
