2022 F3L in limp mode - Code P0122 - what does that mean??
2to3
what does the code: P0122 Throttle Pos Sensor/Switch A Circ Lo Input mean? probably gonna have to tow bike to dealership (100 miles away) but would like to know what to expect. bike is still under warranty.
Thanks for any insight.
I hope my 'forgettory' isn't working over-time atm, but IIRC, that P0122 code generally means you've got a problem with the Throttle Position Sensor either shorting to ground or otherwise getting less voltage than it expects. I reckon there's at least a couple of other threads discussing this Code, so it might be worth your while doing a search & some reading. :thumbup:
But again, IIRC it's usually related to damaged circuit wires (has your Spyder been worked on by anyone? Or any chance you've had some rodents eating wire insulation?); a damaged throttle position sensor; or damaged ECM pins - maybe the plug on either the Throttle Position Sensor or on the ECM itself isn't connected/secured properly, or there's some damaged pins in one of the connectors?? :dontknow:
Regardless, there's probably not too much you should do to sort any of that out on a Spyder that's still under Warranty, altho telling us what year & model might help narrow it down a bit more... Or you could add your Spyder's Year & model to your Sig Line as asked here:
https://www.spyderlovers.com/forums...l-Add-your-Spyder-Year-model-to-your-Sig-Line!
Good Luck with getting your Spyder sorted! :cheers:
bike is 2022 F3L little less than 2000 miles. moth balls all over the garage; rodents not likely...I hope. if wires are rodent chewed, will the warranty cover damage??
