I live in Connecticut and it has been very hot lately. Back in June, I was riding and the temp was about 90 degrees F and my spyder overheated. This is first time this has happened. I noticed a leak, replaced the coolant reservoir and the leak stopped. 2nd time overheating was July 5th. By the time I got home and parked, all the coolant drained out onto a mat under the bike in the garage. This time I drained the coolant, flushed out the tank and refilled with coolant. Let the bike run without the cap for bit, checked the the temp and when the bike was warmed up, the coolant started to rise in the reservoir and was beginnning to bubble big time. How do I fix this problem? Thanks for the support and be blessed!
I understand that back in June, it was hot & your Spyder over-heated, but what actually happened? How long had you been riding for? Did the engine splutter to a stop or just shut down? Did you get any warnings on the dash?? What did the temp gauge do?? How much coolant had leaked out? What did you do after fixing the leak - top the coolant up & continue riding; or wait until it was all cool, then drain everything; back-flush; fix the leak; refill & purge the radiator; or what?? :dontknow:
And more recently, when you say "let the bike run without the cap for a bit" - what sort of 'bit' was that - a minute or two; or 15 minutes?? The coolant "beginning to rise" and those bubbles, can you describe all that a bit more?? :dontknow:
I ask all this, as 'all this' sort of info is very helpful in diagnosing the
actual problem - as others have said, the fix could be as simple as purging the cooling system of all air pockets & topping up (altho I'm sorta doubting that!
), cos while our Spyders are
meant to have a 'self-purging' cooling system, if the air pockets are big enough/deep enough in the system, they just won't self purge - not until it's too late! :shocked: Then there's the way the coolant level rises & bubbles; plus the size, type, & even the way those bubbles pop up - some of those can be a sign of needing a better purge; others can be a sure sign of a blown head gasket &/or cracked block... But we need to know all that to be able to narrow down the suggestions in a way that will really help...
So, can you please fill in a bit more detail about how it all went down? :thumbup:
