packbuckbrew
Just finished a bunch of mods which included adding a Two Brothers carbon fiber pipe. After a test ride, I was checking everything out and noted that the portion of the hitch that covers the axle bolt sticks out far enough that the rear suspension travel allows the pipe to contact the hitch. This resulted in the damage in the photo. DANG! I hope to work around this by 1. adding a washer or two to the pipe mounting to move it out laterally a bit without breaking the seal 2. Trimming off some of the metal on the hitch, this does not appear to be critical to the hitch strength or function, so I think this should be ok to do. 3. Run rear suspension on stiffest setting to decrease chances for contact. I would love to hear anyone else's ideas for dealing with this, and putting the stock pipe back on is not a helpful answer(although it might be the smart answer). In checking out the TB website, they clearly state that this pipe should not be used with a trailer (I thinks what they really mean, is should not be used with the BRP trailer hitch), guess I missed that. Anyone have a thought about the damage to the pipe and whether this will be a problem. In feeling the gouge, it feels like it is only superficially into the fiber, will this hold up if no more damage is done? Is there something I can use to seal up the fiber with that will withstand high temps?
