Original owners......what are your problems?
tfjunkie
Mine is my brakes.
Worked ok at first and then faded.
Twice the shop has done there best to solve the problem...............no joy, works , then same old story.
Been thru 2 dps recalls.
Parking brake failure was....fun eeee, not.
Almost went up in flames 3 times sofar, not fun eee.
Close to original owner
Bought mine with 400 miles on it. Ridden for 2.5 months and put another 2000 miles on it. Ride I a little hard (because it's fun)..... No issues!
Only fixes I've had on my 08 with 17k+ miles so far.
OS Sensor
Oil Sending Unit
Neither of which sidelined the Spyder.
10 RTS 16,500 miles had recalls done , did have a brake problem turns out the cause was low brake pressure in system took 2 days to fix the :spyder2:
Mine is my brakes.
What do you mean almost went up in flames 3 times ??? Either it caught on fire or it didn't . Can you explain this further ???
I have the 08 RS with 57,000 miles and have had all updates done, had issue with front end alignment, had front sprocket issue twice, had clutch basket noise (had it replaced under warranty), have always had brake squeel (have 2nd gen. pads right now) but they stop real well, have had exhaust gaskets replaced at least twice (under warranty) I finally had valves checked at 53,000 miles and all valves were still in spec. but had oil leaks at valve cover gaskets after valve insp (new ones under warranty), sputtering between 3,000 and 4,000 RPMS and now I am starting to loose functions on display like total hours, and trip hours. I do my own oil changes and lubrication of struts etc. and other regular maintenace. I also have had to change what dealer I deal, with going from one 5 miles away to one 60 miles away. Over all I have been very happy and excited to have the Spyder and ryde whenever we can!:thumbup:
Original owner problems
Virtually no problems. The updates were not all done upon delivery, but that's no big deal. I have 4,300 miles since Aug 21 and I'm a happy guy. Gas mileage could be beter, but I knew that when I bought it.
Tuck
2009 RS SE5 with 26k+ miles. Other than recalls, updates and normal maintenance, my :spyder: has been hassle free and a total joy to ryde. As with my toys, tools, home aad health, I hope that continues. :pray:
Most of the problem with mine has been with the loose nut behind the handlebars... :opps: And Subarus! :D
I've got an issue with the throttle bodies; hopefully it'll get worked out after they get done making things straight again!
Virtually no problems on any of the three that I have had.
2008 GS SM5: 22,500 no problems other than factory recall service. traded at 22,500 on 2010 RTS.
2009 RS SE5: 22,000 and still going. Computer crash at 1500 miles. Parking brake adjustment issues. Factory recalls.
2010 RTS: 22,000 and still going. Recalls and a stripped wire causing problems when wet. Replaced rear brakes at 21,000.
I consider myself lucky and have not had any :spyder2: to date that has encountered major mechanical problems or downtime.
Also i had stumbling at 3-4k rpm....and coolant leaking from the pump.
On the burn up....
First time was after filling up on a hot day....fumes ignited.
Second time ....over fill spill........did not ignite , thankfully
Most recently.....smelled gas after start up....raw gas leaking on r/s ....
Took plastic off.....leak is either at the line crimp clamps or the center fold of the filter.
Working on narrowing it down.
I really want my brakes better.........................ANYONE?
:banghead:
We picked up an 09 rs for the wife. I think the biggest problem has been i turned a nut loose between the steering wheel and the seat. :yikes:
+My 2008 SM5 Roadster Red GS has 52,000 problem-free miles with the exception of the rear fender struts cracking. The first replacements were covered by warranty, the second replacements weren't and are stored in the garage awaiting install, probably in a few thousand miles. Regular maintenance stuff has been replaced, like a headlamp and a fender lamp, and the seeming front end alignment concern disappeared and never resurfaced when I stopped using the OEM tires.
OEM
http://www.roadkillonline.net/imagedb_images/35_10172.JPG
Bridgestone Potenzas
http://www.roadkillonline.net/imagedb_images/35_10150.JPG
http://www.roadkillonline.net/imagedb_images/35_10178.JPG
Rear tire keeps burning off, for some reason...
I'm very happy with the bike.
Ride on.
Roadkill
And thank you folks for reminding me about ........my taillight......i am on my 3rd one.
same thing all the time.
Plastic comes off and i am looking at my tail light and the hold screw for the entire assembly.
My guess is the plastic at the hold screw needs to be ....thicker... to handle any thing going on at the location.
Brakes...............anyone,,,,,:dontknow:
I have a 2011 RS-S with 3,600 miles. I had noise and took the the left side panels off and the clips on the air box are not fitted and swing back and forth. The other that causes alot of problems is heat buildup caused by the headers. I am going to put on header tape on and see if it lowers heat buildup that is 290 deg. when outside temp. is 89 deg.
Mike
Interesting thread
17,000 miles since May26th 2011 on this Spyder & Teds Red Sled has a bald tire getting replaced by the Great Folks at Middletown Cycle on Tuesday.
We can't seem to get enough ryde time:dontknow:
9000 miles since new in april of 2011
NO issues, no faults, 7000 of those mile with loaded trailer = rear tire at wear bars.
