DriftersWay
I have a 2022 F3-L ordered due to arrive in Feb. My question is
Can the rear trunk be removed for a sporty look around town?
Your post says you ordered an F3L. Most of the above responses are for RT's. If the 2022 F3 stays the same as the 2021 the answer is no. The topcase can be released to access the area underneath, but there is no provision for a cover. Also, the radio antenna wire to the front and a large ground wire are more or less permanent.
:agree: Keep in mind that the 2016 F3L did not even have a trunk. But just like the F3T, the trunk could be added. If you want to add a trunk to the newer F3T, i am thinking you will have to add a 2018 or older trunk, which does not require the linq system.It removes. You can buy the F3T cowl and antenna assembly. Look on the left side, above the saddlebag. There is an area that resembles a “U”. That is where the F3T antenna mounts. Joe
It can definitely be done. For me, that cover for the rear would be the one item that I would negotiate with the dealership on including in the sale. I say that only because I know I would be wanting to ride without the trunk quite a bit. I would try the same thing with the 2020 and newer RT Limited.I recently watched a video on you tube that showed an 2021 F3L top case being removed and a back fairing being added. I will look for it later today.
i have the same thoughts with my 2021 F3L, however i have not been able to find the fairing cover, not even through my dealer. I don't get it as you would think it's the same piece that's on the F3T...???
I'm surprised you, or anyone else who has responded, hasn't cited the 2022 Operator's Guide, https://www.operatorsguides.brp.com/public/get_public_guide.php?idGuide=10990. Instructions for removing the top case are provided on page 40.I have a 2022 F3-L ordered due to arrive in Feb. My question is
I'm surprised you, or anyone else who has responded, hasn't cited the 2022 Operator's Guide, https://www.operatorsguides.brp.com/public/get_public_guide.php?idGuide=10990. Instructions for removing the top case are provided on page 50.
On the BRP website for LinQ accessories there is this rack that will go in the place of the top case if you want. https://can-am-shop.brp.com/on-road/us/en/219400743-top-case-rack.html. I don't find any info on a decorative panel to put in the place of the top case. Although, the implication from the description of the rack is that the RT panel may fit. The LinQ system appears to be the same for the F3 and RT and is a universal accessory mounting system. It is used across the board on BRP recreational vehicles, as well as other brands. With a deep search all over the place you may find a cover or panel that will blend well with the F3 when the top case is off.
