Options for XM radio
2manycars
I just bought an RT-S and would prefer not to spend the $550 for the BRP XM unit. What other options are there, and can you control any of them through the control stalk and have the unit in the trunk?
I believe Lamont & others have posted that they can use an XM app on their iPhones & run it through the AUX input. Give the board a search and see what you come up with. It might be the solution you're looking for.
I mounted a thin car automobile unit in the "glovebox."
I had forgotten that I owned a sirius unit already, and found it fit fairly well in the glovebox. I had to drill one hole in the rear box to route the wires, and cut a notch in the edge of the glovebox for the wires as well. I cut the notch and reinserted the rubber on the glovebox to keep it pretty much watertight.
I do not change station soften, but rather than not being able to do so at all without dismounting the RT, I can now change stations at a light etc.
