krb1945
As some of you know I have three spyders... 2 2008 SM5's and 1 2009 SE5. I am also one of the riders that is having trouble getting one of the 08's belt to adjust properly . It is either against the inner rear sprocket flange or at the extreme outside edge.
I adjusted two of the spyders belts... to about 1/8 inch off the rear inner flange... took all of about 1 hour for both of them. But this PE 0548 has been a nightmare. On three different occasions I have spent more than an hour and still no satisfactory adjustment.:gaah:
Please look at these pictures and see if you see any problems with this front sprocket. Torque on the sprocket bolt is 89 Ft Lb and there is no play in the shaft bearing. Everything is snug just the way it should be.
Also the belt is between 220 and 240 on tension and the rear bearings seem fine... no play and no bearing noise.
Any tips would be greatly appreciated. Ken krb1945
