One cylinder Spyder
bigarachnid
2008 Spyder #608. I stopped for gas. When I fired up, it was only firing on one cylinder, and I limped it home. No spark to one cylinder. Displays code O P0351. What's that? Do I need a new coil pack or an ECM? Help.
P0351 - Ignition coil stage 1 short to 12V or to ground Causes: blown fuse, damaged circuit wires, damaged connector, damaged or disconnected ignition coil. Not likely fuse F8 since the other side of the coil fires. There are several specific tests to pin it down further.
I had that same code #P0351 for the coil a few years ago. Once the dealer did further checking it turned out to be the ECM was bad and not the coil.
thanks
Thanks for the info. Not sure if that's good news or bad news. More testing today to try to determine if it's the coil pack or ECM. I'm sure the coil would be cheaper than an ECM.
Just throwing this in , Will a bad spark plug wire [arcing] also throw that code?? :dontknow:
The stock wires have been known to give up the ghost too easy.
