Peteoz
Well-known member
I have just installed Lamont’s new Heim links (To reduce the frequency between the ball heads clagging up)
Ran the RT up on the ramps which should be OK to R&R the links. It’s a bit fiddly to get at the bolts/nuts with that bit less clearance, but manageable……and of course, it needs a 13mm wrench, which is the one wrench not in my kit that I took down to the floor with me to save getting up and down. I finally found one, removed the old link, and after a lot of fiddling got the new link in to the confined space and torqued it up. OK……Time for the left side……hang on, why are there two Lamonster links sitting under here? Yep, yep, yep, I had exasperated myself soooooo much trying to find the cursed 13mm wrench that I had picked up the old link and reinstalled it:yikes: …..mind you, it fitted perfectly :roflblack:
A few choice words were uttered (well, maybe more than a few, and maybe louder than muttered, as my wife cam out to see if I had broken a limb……or spilt my beer), then out with the new/old link, and in with the Lamonster link, which of course, was even more difficult to get in than the previous redundant install. I then removed the second link and tossed both old links quite some distance from where I was working. The second new link went in relatively easily.
The old links did have the final word, however……I took my shoes off to go inside, as as I crossed the garage, I didn’t see that one of the little buggers had bounced off a wall and was right where I took a step. My wife didn’t bother coming out to check on the noise this time :roflblack:
It’s 11am……I’m ready to have that beer now :2thumbs:
