Oil tank strainer - O ring???
dliszews
Is the O ring on the oil strainer a standard size available at an auto supply? Trying to avoid
ordering something this common.
If you want to try to match it up, the one on the dipstick is the same. Not sure that you will find one, this one is pretty thick and pretty soft. To be sure not to lose any oil after it is replaced, I'd get one from a Spyder dealer. BTW, if the purpose is just to clean your strainer, The o-ring is usually not damaged. Clean it and inspect it, lubricate it and reuse it.
Ah, now there you go with reason and logic again! How is anyone going to make a buck with this approach? :lecturef_smilie:
