On the bottom of the engine, right side, is the gear shift linkage which appears to be connected to the engine via a rubber boot which is held on by a black plastic tie. Every time I do an oil change, there is a drop of oil clinging to the bottom of the boot and some evidence of it collecting on the inside of the plastic cover. It isn't a large amount by any means, probably no more than 20-25 drops total over a 3,000 - 3,500 mile time period and has never ever leaked enough to collect on the garage floor.
I checked today thoroughly and found no evidence of any oil coming from anywhere above the boot. Wondering if I should ignore it, or remove the plastic tie and put in a new one, in case this one was not pulled tight enough during assembly before they cut the loose end off.
