I am looking for some advice. I have an oil leak on the right hand side. It is showing up on the right underside protective panel. I know it is not coming from the air box area as I have had this apart and it is clean. I also have a catch can installed to be sure no oil reaches the air filter box. I have checked the crankcase oil plug and the oil tank plug and have seen no obvious leakage. The dealer said it most likely oil in the air box.
Any suggestions where to look at next or how to find the leak would be appreciated.
I also have a check engine light come on when I first take off on the spyder. This stared when I installed the juice box pro. I have it set at setting 2. This is based on having a hindle and green filter installed. Any suggestions.
Thanks
Thanks
