Oil leak 2013 rt ltd
TXSHOTGUN
I have developed an oil leak. the oil is running down the center of the front cyl and getting on the main lower frame brace. I have checked the main oil line and it is not leaking. It appears it could be valve cover. I just installed JT air cleaner and i presumed the leak was coming out of the air box, and it had quite a bit of oil in it. After i installed it and buttoned the tupperware back up the leak continued after engine got to normal operating temp. Would their be another line that i am not seeing that could be leaking.
thanks
Little checking..!!
have seen some instances that the valve cover gaskets leak. Have you had any work done recently..? Lotsa work but you clean off the area with contact cleaner and fire her up watching for the path the leak takes...good luck and let us know when you find it...:gaah:
