Oil Filters Backordered for RT Until September????????????
Several people have reported this znd they were pooh poohed.
Thanx Ann, I was one of the ones who was poohed poohed. My dealer is just as frustrated as I am with not being able to get the oil filter for my 2014 RT. I called 4 other dealers and finally found one who has them. They are sending a couple to my dealer....one to use now and I will keep the other for a spare for my next oil change.
Semi-Guilty as charged. I was pooh-poohing the dealer that said they couldn't get them (not the poster(s). This based upon the fact that I was able to get them easily from my dealer and the assumption that BRP would not let this happen.
If my PP'ing was misdirected I apologize.
And how does that compare to this?
http://www.ebay.com/sch/i.html?_odk...ter&_nkw=seadoo+oil+filter&_sacat=0&_from=R40
Sent from my Venue 8 3830 using Tapatalk
Assume you mean this one? http://www.ebay.com/itm/OIL-FILTER-..._Watercraft_Parts&hash=item4ac5e9addc&vxp=mtr
Buy one and send me the measurements and I'll compare it to the new '14 filter that I have on hand.
May stop at my dealer tmr; if so, will compare the two filters. Only diff in stock numbers are the last digit, Seadoo being a "1" and the Can Am "3".
I am semi-guilty of not realizing you were PP'ing my dealer and not me. I appreciate your post Ron, thank you!
I went by the local dealer and picked up a filter. Took it in the shorts on price. Retail is $15.99 and they charged $19.29.
But FWIW Broward Motorsports in West Palm has a bag of filters if anyone needs one.
Filter PN is 420956743
Dimensions are as follows
Overall length excluding grommets 98.3mm
Overall length including grommets 106.7mm
Outside diameter (metal edge) 56.5mm
Inside Diameter (grommets) 25.0mm
Consider that the grommets must be able to handle the pressure diff across the filter element.
PK
The grommets are just to seal the ends. Usually a filter only needs 1 end open, otherwise the oil could enter and exit without going through the filter at all. Even filters with 2 grommets don't necessarily need them (as in the original OEM trans filters) as the 2nd grommet simply seals against the outer cap. They could just as easily (and more cheaply) put a blind end cap on the filter itself.
If this was the case with the 1330 ACE motor we could simply use the engine filter used on all of the earlier models. But, in this case it appears both ends being open (with grommet) is functional and the system will not work without both ends being open.
This is what happens when you re-invent the wheel.
Some good news. The filter outage does not appear to be an epidemic.
I am finding out that "dealers in the know" seem to have them. I ordered two of the kits from one this AM.
So you take one of the older type, put a hole cutter in your drill press, drill out the metal end, add a grommet off the OEM you just removed! I've got two prepared, but haven't the urge yet to try them; besides I have an extra OEM on the shelf! :D
I have one at our shop that I could measure and post up. I won't be over there until the weekend though...
SeaDoo Filter same size as Can Am '14 Filter
Stopped by dealer today and compared SeaDoo 420956741 to Spyder 420956743 and they are IDENTICAL in SIZE with the same grommets on both ends.
Construction of the Seadoo filter is much like the Hiflo used in pre-14's; that is, it does not have the outer wire construction. However, many of us have used Hiflo filters exclusively with no issues that I've heard of.
Therefore I can see no problem with using the Seadoo if you can't find the Spyder one. Priced about $12 vs $16.
Let me point out that I'm not a mechanic, and not proposing that any of you do this. Its strictly your call.
Maybe someone with more knowledge of the 1330 motor and its oil pressure system can chime in on this subject.
I've emailed BRP asking them if the two are interchangeable.
Heres what the Seadoo filter looks like:
http://www.ebay.com/itm/4-STROKE-OIL-FILTER-SKI-DOO-LYNX-SEA-DOO-EVINRUDE-JOHNSON-ROTAX-CAN-AM-420956741-/261222557827?pt=Personal_Watercraft_Parts&hash=item3cd213e883&vxp=mtr
Cool! Looks like the problem is solved. K&N also makes a filter that many seadoo peeps choose.
You all can be assured that if it holds up in a 1500cc supercharged engine putting out 260+ hp with long extended times of running 8k+ rpms, that it will surely hold up in the 1330 motor..... [emoji106]
So I got curious as to my dealership having oil filters in stock since I'm taking my RT in for 3k mile service and some warranty work on Friday (ignition/frunk issue, leaking rear shock).
Service told me they had plenty in stock if I wanted extras since hubby will do all oil changes after this; I could buy the kit or the individual filters and O rings. No problem on the supplies here......
What is the K&N number? KN556? kept popping up while I was researching but it appears to have a closed end so that won't work. Also, I think K&N's are made by Hiflo...or at least some are.
All K&N oil filters are made by HiFlo. Air filters are made by K&N.
If the physical dimensions are the same, then it should work. The business of regulating the filter is done by the stem that goes through the middle. The filter is the filter, size of the filter media is the only difference that could be. The stem that goes through the middle is old school motorcycle technology and has been in use for somewhere around 40 years or so.
First service completed on 2014 RT L - all parts in stock - YES!
Hello fellow Spyderlovers,
I had my dealer just complete my first service / oil change on my 2014 RT L. I asked when I set it up if there were any issues with parts, and the service manager said no.
He is credible! :D:thumbup: Just got home after being at the dealer for my first service. No issues whatsoever! :thumbup: NO mention of any parts (i.e. filter) for the oil change in backorder or any other issues.
As a matter of fact, while I was at the dealer, I purchased a complete set of O-rings, washers, filter, etc. for my next oil change -- all in stock. :clap::clap::clap::clap:
Are all of you really going to wait the "
EVERY 15 000KM (9,300MI) OR 1 YEAR (WHICHEVER COMES FIRST)" to change your oil again???:shocked::dontknow:
I think I'll get it on the 5000 mile intervals from now on -- any thoughts? :dontknow::dontknow:
A good question indeed concerning oil change intervals. A 9300 mile interval does seem long in the scheme of things. Coupled with the once a year, regardless, does seem to temper the situation though. Most riders with a short summer season are not going to encounter the 9300 miles--so there is a safety margin there.
Those of us in the high miles club may want to consider a more frequent interval.
I don't personally have the answer--just throwing some ideas out for a brainstorming session.
:popcorn::popcorn::popcorn:
Reply (or Non-Reply) from BRP re' alternate use of SeaDoo Oil Filter
I really expected better of BRP but perhaps my query never got to the technical types. Heres what I asked and following is the classic CYA beaurecratic answer: :mad:
"Is there any reason this Seadoo oil filter 420956741 should not be used in a Can Am RT SE6 in place of 420956743? I cannot imagine the 1330 ACE having more oil pressure than the 4-Tec Seadoo motor and requiring the wirebraced filter now being used in the 1330. Thanks"
"In response to your request BRP does not recommend modification to the units. As mentioned in the exclusions of the warranty section of the operator's guide, the following are not covered under the manufacturing warranty;
• Normal wear and tear;
• Routine maintenance items, tune ups, adjustments;
• Damage caused by failure to provide proper maintenance, operation, care, service or storage;
• Damage resulting from removal of parts, improper repairs, service maintenance, modifications, or use of parts or accessories not manufactured or approved by BRP or repairs done by a person that is not an authorized servicing BRP dealer;
• etc;"
