ulflyer
Tried and True Method to loosen Drain Plugs
"A friend of mine had the same problem he use a sharp screwdriver put it along the edge and lightly tapped it with a hammer and a loosened it up." mentioned above.
This basic method has been used for ages on hard to loosen plugs or those stripped out. Mechanics often use a chisel which has a sharp edge, placed at an angle, hit sharply with a hammer. Takes much less than you expect to loosen it. Worked on my '11 and last year on the '14.
