Oil Change
DragonSpyder
After draining the oil today I put 4 quarts in before starting it. The manual says put in 3 then run for 3 minutes. Any idea why they tell you that? All 4 seemed to fit in the tank....
good question
Good question, inquiring minds want to know, I am sure there is a valid reason however I have never done it this way on any of my prior bikes . I followed the instructions and put in the 3 then ran the engine and put in the other quart, however now you have me wondering as well, some one in the know will have the answer I hope. :hun:
Corvette dry sump oil change procedure is the same. Run engine, add last quart. I think it is done to make sure you don't overfill in case old oil wasn't completely drained.
When adding oil to a completely drained crankcase / oil tank (in some cases), the oil doesn't necessarily fill every nook and cranny with only gravity helping it. When the engine is run, the oil pump fills all the voids and effectively distributes the oil throughout the engine. The only risk by adding all the oil at once is an "artifically" high oil level that MAY result in some slight (momentary) foaming and possibly oil being forced out the breather.
