Oetiker Clamps
The Oetiker clamp size for the 1330 lower radiator hose at the radiator end is; number on Oetiker clamp is 36.1...ID measures about 1.456 or 36.98 mm X .290/7.38 mm wide...
Mr. larryd,
A scholar and gentleman. Thank you. I really appreciate the hands on answer you provided, only took 20 times to get it. A lot of trolling going on here!
That one appears to be the predominant one, uses at 10 places. Of course BRP uses different numbers on the illustrations to identify the same part numbered pieces, make the job so much easier!
Also, an easy tool for closing and cutting open Oetiker clamps are the type of dykes the have the cutting jaw on the end of the pliers instead of on the side...Some call the tack pulling pliers...I'm not sure of the actual name of those type of dykes...But I do own several pairs along with two of actual Ortiker tools the have both the side and end cutters and crimpers...larryd
Found my missing notes. Double checked my info. Ordered clamps today. If I can get them installed this week I will PM the part numbers to you.
